Hade detta liggande som 'bra o ha', det är bara att räkna ihop det du kan tänka dig att vara utan
Weight reduction
You can achieve substantial weight reduction with the following modifications, while still having a car that's very comfortable to drive. Most of these modifications will directly increase (and decrease in a few cases) the safety of the car, while safety is indirectly improved due to the better handling and limits of a lighter car. Fighter pilots say "speed is life". Acceleration, deceleration, and lateral acceleration are all forms of acceleration, and lighter cars accelerate better in each of these ways because the tires have less mass to control....thus a lighter car is a safer car. Lighter cars have better moments of inertia which allows them to turn in more easily and roll less. Lighter cars are also easier on the tires and gas.
Stage I: Streetable weight reduction mods
Braking rotors with an aluminum hat, or titanium rotors (unproven on street cars) (~20-30 lbs)
Carbon fiber hood (~12 lbs)
(thinner) windshield and side windows (~5.7 lbs)
Non runflat tires (~20 lbs)
Slicks (~30 lbs)
Titanium exhaust (~35 lbs)
Long tube headers (~20 lbs)
Halltech aluminum alternator & bracket (10 lbs)
Carbon fiber driveshaft (~2 lbs)
Less options [HUD, elec AC, Active Stability, seat/mirror/steering wheel memory, cd changer] (~50 lbs)
Less gasoline & wiper fluid (No wiper fluid=9lbs, 6 lbs for every gallon of gas in that 18 gallon tank....~81 lbs for autocrossing)
Remove
cargo net
targa top (~20 lbs)
"appearance mods" - exhaust plates, doorsill covers, etc.
fuel rail covers
all loose change, CD's, golf clubs, misc. items, from center console, hatch area, and glove box
Replace
stock crank pulley with aluminum aftermarket pulley
steel dampener with aluminum dampener
stock targa top with lexan piece (coupes)
water pump with electric water pump
battery with smaller battery
non-stressed fasteners with aluminum or titanium fasteners
leaf springs with coil over shocks with titanium springs
steel shifter with aluminum shifter and delrin or titanium shift knob
Empty your pockets of extra change, PDA's, cell phones, keys, lead plates, or whatever other junk you lug around
Go on a diet
=p
Stage II: Hardcore semi-streetable weight reduction mods
Aluminum flywheel (~10 lbs)
Lighter clutch like Exedy or Quartermaster (~10 lbs)
Racing buckets (40-50 lbs)
Off-road x-pipe (10 lbs)
Replace stock hood, fenders, doors, roof, hatch and bumpers with aftermarket carbon fiber pieces
Remove
Floor mats
Fog lights
Stage III: Track only weight reduction mods
Racing steering wheel & delete both airbags (~30 lbs, but get a 4-6 point harness)
Use unpadded aluminum or carbon fiber steering wheel
Run open headers
Replace stock front and rear glass with polycarbonate “glass”
Rebuild motor with Al or Ti connecting rods, Ti valve spring retainers and pushrods
Port the heads
Replace valve covers with magnesium or carbon fiber parts
Strip entire car, acid wash chassis, put car back together.
Remove
Column locking hardware
Interior – passenger seat, carpets, speaker panels, head liner, dash, center console, glove box, door panels, sun visors, rear view mirror, insulation, etc.
A/C Compressor
A/C controls and ducting
AIR pump system
Factory radio, speakers, and/or CD changer, and unnecessary wiring
HUD projector
Windshield wiper fluid reservoir and pump
Windshield wipers and motors
Stock cat back
Power steering pump
Front sway bar (drag only)
ABS, TC, AH hardware and sensors (drag only)
Fender wells
Headlight assembly, turn signals, taillights and reflectors
Shave side mirrors
Torque tunnel cover
OEM seat belts
Parking brake
Side windows and motors
Power locks and power windows
Side impact beams
Casting flash from engine, then polish
Reducing unsprung weight—not all is streetable
Forged 1-piece wheels
Use 3-piece wheels by Jongbloed, Kodiak, CCW, BBS
Skinny front wheels (drag only)
Ti fasteners on 3-piece wheels (~1 lbs per wheel)
Lighter non-runflat tires, or even track only synthetic corded slicks
Lighter calipers
2-piece, unvented or titanium rotors
Titanium wheel studs
Aluminum or titanium lug nuts
Remove tire pressure sensors
Remove rubber valve stem cap
Balance the wheels without tires or balancing weights, and then mount tires
C6 Suspension weights
Z51 rotors
17 lb, 14 oz - front rotor
24 lb, 16 oz - rear rotor
Drivetrain
Clutch/Flywheel
23.3 lbs - O.E. iron flywheel
44.8 lbs - O.E. flywheel/clutch assembly
49 lbs - Z06 clutch/flywheel assembly
42.8 lbs - Z06 stock
36.7 lbs - Exedy Single Disk
36.7 lbs - Exedy Dual Disk
12.4 lbs - Fidanza flywheel
33.9 lbs - Fidanza flywheel & SPEC clutch assembly
14 lbs - Quartermaster 5.5" 3-disc clutch/flywheel/hardware
115-129 lbs - T56 transmission, TUET1806
21 lbs - DTE A4 Differential Strut Kit, Stage I
Motor & accessories
457.6 lbs, auto; 497.2 lbs, manual
30 lbs - AC/condenser/lines/oil holder/brackets/pulleys
10-3/4 oz - airbridge
1 lb, 14 oz - radiator top cover with screws (x4)
1 lb, 12 oz - fuel rail covers
16 lbs - P1SC head unit
14 lbs - A&A single intercooler
8 oz -- Headlight relay
2.5 oz -- OEM air filter clip/band x2
6 oz -- Serpentine belt OEM
4.25 lbs -- OEM airfilter assembly without any clamps of any sort
10.5 oz -- OEM air bridge
2.1 oz -- Timing belt cover
92.5 lbs - Aluminum block - GM Manual, JRP's SuperFAQ
18.9 lbs - Aluminum head - GM Manual, JRP's SuperFAQ
10.25 lbs - water pump
15.5 oz - piston
480 gm - LS7 titanium connecting rod
~685 gm - LS2/3 connecting rod
76 gm - LS7 intake valve (2.200)
71 gm - LS7 exhaust valve (1.600)
Quote:
The lightweight titanium valves weigh 21grams less than the stainless steel valves used in the LS2/LS3, despite the valve head having 22 percent more area.
Batteries
13 lbs - Odyssey/Dynabatt/Hawker racing battery
13.5 lbs - Genesis G16EP, LWH=7.15x3.01x6.65, CC=280
15 lbs - PC 680, LWH=7.27x3.12x6.67, CC=280
23 lbs - SVR SVR28-12, LWH=6.88x6.50x4.88
23 lbs - Genesis G26EP, LWH=6.57x6.92x4.96, CC=470
26 lbs - Odyssey PC 925, LWH=6.69x7.05x5.04, CC=470
26 lbs - SVR SVR33-12, LWH=7.75x5.00x7.25, CC=500
26 lbs - Optima Yellow Top 51, LWH=9.25x5.00x9.00, CC=500
32.8 lbs - AC Delco 75P-7YR, LWH=9.50x7.10x7.30, CC=550
32.9 lbs - Genesis G42EP, LWH=7.78x6.53x6.72, CC=630
35.4 lbs - Odyssey PC 1200, LWH=7.87x6.66x7.55, CC=630
33.1 lbs - Optima Red Top 75/35, LWH=9.31x6.81x7.63, CC=650
37.7 lbs - AC Delco 34P-7YR, LWH=10.3x6.80x7.80, CC=650
36 lbs - Exide Select Orbital 75, LWH=9.00x7.00x7.44, CC=690
38.8 lbs - Optima Red Top 34/78, LWH=10.0x6.88x7.81, CC=750
38 lbs - Exide Select Orbital 78, LWH=10.1x7.00x8.1, CC=770
45.6 lbs - AC Delco 65P-7YR, LWH=11.9x7.50x7.60, CC=800
57 lbs - SVR SVR80-12, LWH=10.6x6.50x6.25, CC=800
58.7 lbs - Odyssey PC 1700, LWH=13.02x6.62x7.68, CC=930
Exhaust
Headers with X-pipe unless noted otherwise
72.5 lbs - cast iron manifolds with pup cats & h-pipe
49 lbs - Kooks LT's w/high-flow cats - Src
Body
9.0 lbs - Window glass (left)
9.0 lbs - Window glass (right)
36.09 lbs - Windshield
3.0 lbs - Exterior rear view mirror (left)
3.0 lbs - Exterior rear view mirror (right)
6.2 lbs - Stock tunnel plate
15.4 lbs - Elite Engineering 304 SS, 0.134" tunnel plate, uncoated
9.4 lbs - Elite Engineering aluminum 1/4" tunnel plate, uncoated
9.6 lbs - Elite Engineering aluminum 1/4" tunnel plate, coated
14.6 lbs - Elite Engineering aluminum 3/8" tunnel plate, coated
1/2 oz - part# 11515757, crashbar bolt
1/4 oz - part# 10281493, crashbar nutsert (big)
1/2 oz - part# 10281487, crashbar nutsert (small) (x4)
1/2 oz - part# 10#11515638, radiator/bumper nut-speci (x4)
1/2 oz - part# 11513568, radiator/bumper screws (x3)
1 oz - front spring to subframe bolt
502 lbs - frame
30.4 lbs - Hood & substrate (no light)
14 lbs - 100% carbon fiber hood
5.26 lbs - Stock 63mm driveshaft, part #12564457
4.56 lbs - PFADT & LG carbon fiber driveshaft
5 oz - Air dam - right side
20.22 lbs - C6 transparent roof
20.90 lbs - C6 painted roof
Interior
3.5 lbs - Driver side air bag
8.5 lbs - Passenger air bag
3.5 lbs - Driver side seatbelt
4 lbs - Interior fan motor
8 lbs - Front speakers
18.0 lbs - HVAC (base under dash unit
4.0 lbs - Blower motor (Heat/AC)
2.0 lbs - HVAC plastic ducts
4.0 lbs - Airbag/glove box aluminum support
2.0 lbs - Aluminum center console support
1.0 lbs - A/C control head
2.0 lbs - Dash vent duct
1.0 lbs - Knee bolster support (white foam)
1.0 lbs - Bose radio amplifier box
3.0 lbs - Radio, AM/FM/CD
7.0 lbs - Door module, harness, regulator (left)
7.0 lbs - Door module, harness, regulator (right)
3.0 lbs - Glove box assembly
3.0 lbs - Door speaker (left)
3.0 lbs - Door speaker (right)
3 lb, 8 oz - driver side seat belt and fasteners
11 oz - cd changer pack, no cds
6-1/2 oz - 12 cds
2 lb, 2 oz - trunk side storage covers, both
1 lb, 10 oz - passenger floormat
2.5 oz - Right seat button surround part # 1027308
2.5 oz - Ashtray
3 oz - Driver's seat frame plastic bracket covers and front bolts
5 oz - Seat belt top bolt and covers
1.5 oz - Dashboard cigarette lighter male & female
Seats
Sparco - Src
I'm using the Sparco Evo 2 as the largest possible seat that can fit, so all the seats below should fit. 20.91"/531mm base, 23.66"/601mm shoulder
18.00 lbs - Sprint (steel tube)
15.00 lbs - Ultra (fiberglass)
16.50 lbs - Off Road (fiberglass)
18.50 lbs - All Road (fiberglass)
21.50 lbs - Pro 2000 (fiberglass)
13.00 lbs - Pro 2000 (carbon fiber)
18.50 lbs - Evo (fiberglass)
12.50 lbs - Evo (carbon fiber)
20.00 lbs - Evo 2 (fiberglass)
17.50 lbs - Pro WRC (fiberglass)
14.50 lbs - Pro WRC (carbon fiber)
18.00 lbs - Rev (fiberglass)
22.00 lbs - Corsa (fiberglass)
12.50 lbs - Corsa (carbon fiber)
25.00 lbs - Circuit (fiberglass)
15.00 lbs - Circuit S-light (carbon fiber)
14.00 lbs - S-light (carbon fiber)
17.00 lbs - Speed (steel tube)
44.00 lbs - Milano (steel tube)
40.00 lbs - Monza (steel tube)
40.00 lbs - Torino (steel tube)
48.00 lbs - Milano Presige (steel tube)
16.00 lbs - Roadster (fiberglass)
20.00 lbs - Fighter (fiberglass)
Cobra seats
14.3 lbs - Aqua 4x4 (fiberglass)
17.6 lbs - Evolution (fiberglass)
14.1 lbs - Evolution Technology (carbon fiber)
14.3 lbs - Imola (fiberglass)
11.2 lbs - Imola Technology (carbon fiber)
15.4 lbs - Suzuka (fiberglass)
12.3 lbs - Suzuka Technology (carbon fiber)
19.8 lbs - Monaco (steel)
12.00 lbs - Aerosport AS100
7.50 lbs - Aerosport AS100/CK
12.00 lbs - Aerosport AS100N
7.50 lbs - Aerosport AS100N/CK
16.00 lbs - Aerosport AS200
30.00 lbs - Corbeau A4
12.00 lbs - Corbeau Classic Bucket
21.00 lbs - Corbeau Classic II
16.00 lbs - Corbeau Forza
25.00 lbs - Corbeau GT7
12.00 lbs - Corbeau GTA Lo Back
10.50 lbs - Corbeau Monza
42.00 lbs - Koenig Bio-Med
32.00 lbs - Koenig CL200
32.00 lbs - Koenig CP200
30.00 lbs - Koenig CP700
28.00 lbs - Koenig CPK700
38.00 lbs - Koenig K370
38.00 lbs - Koenig K530
38.00 lbs - Koenig K4000
31.00 lbs - Koenig K5000
31.00 lbs - Koenig K5000G
36.00 lbs - Koenig Miata
32.00 lbs - Koenig RL200
12.00 lbs - Koenig RS1000
10.00 lbs - Koenig RS2000
10.00 lbs - Koenig RS3000
26.00 lbs - Koenig S50
30.00 lbs - Koenig S100
28.00 lbs - Koenig SP700
28.00 lbs - Koenig Speedster
12.60 lbs - Momo Start
16.90 lbs - Momo T-Frame
14.70 lbs - NEX Racing Seat
16.50 lbs - NEX Reclinable Racing Seat
13.20 lbs - OMP Champion
18.50 lbs - OMP Eco
15.00 lbs - OMP Evoluzione
24.30 lbs - OMP Rec
24.30 lbs - OMP Red
19.00 lbs - OMP San Remo
14.30 lbs - OMP Sport
19.80 lbs - OMP Strada
19.50 lbs - Procar by Scat, Race 1600 Series
16.50 lbs - Procar by Scat, Xtreme 1700 Series
14.30 lbs - RaceTech JetSprint
16.50 lbs - RaceTech ProSprint
18.70 lbs - RaceTech RAC 4009
13.20 lbs - RaceTech RAC 9000
14.30 lbs - RaceTech RAC 9009
9.90 lbs - Recaro SPA
12.10 lbs - SPA Racer
Corvette Vehicle Dismantling Manual
24.80 kg - Front tire (2)
0.42 kg - Engine Oil Filter
16.3 kg - Battery
3.48 kg - Passenger Air Bag
0.26 kg - Fuel Tank Isolator
11.21 kg - Fuel Tank (2)
26.80 kg - Rear Tire (2)
1.53 kg - Driver Side Air Bag (1)
0.20 kg - Wheel Weights (4)
0.78 kg - Side Air Bag (2)
0.62 kg - Seat Belt Pretensioner (2)
14.49 kg - Windshield
7.04 kg - Front door window, lh, rh (2)
12.86 kg - Front door, lh, rh (2)
0.72 kg - Front door weatherstrip (2)
1.12 kg - Windshield opening weatherstrip
3.50 kg - Lift off roof panel
1.15 kg - Lift off panel rear weatherstrip
10.47 kg - Back window
0.40 kg - Lift off panel side weatherstrip (2)
10.5 kg - Hood
0.46 kg - Front wheelhouse extension (2)
6.97 kg - Front bumper fascia
1.66 kg - Front bumper energy absorber
0.33 kg - Front fender brake cooler duct (2)
3.85 kg - Front fender, right
0.79 kg - Front wheelhouse lower rear closeout (2)
0.79 kg - Front wheelhouse lower front closeout (2)
3.82 kg - Front fender, left
3.50 kg - Quarter panel, right rear
4.32 kg - Axle assembly boot, lh, rh (2)
4.12 kg - Rear Wheelhouse liner, lh, rh (2)
3.57 kg - Quarter panel, left rear
1.76 kg - Rear bumper energy absorber
7.00 kg - Rear bumper fascia
2.16 kg - Lower rear fascia
0.45 kg - Grille
1.34 kg - Front seat foam, lower, lh, rh (2)
0.30 kg - Front seat belt webbing (2)
1.09 kg - Front seat foam, center, lh, rh (2)
1.48 kg - Front seat foam, upper, lh, rh (2)
5.97 kg - Front seat frame back (2)
0.34 kg - Hood weatherstrip
0.15 kg - Master cylinder reservoir
1.24 kg - Valve cover shield (2)
3.64 kg - Intake manifold
0.49 kg - Battery tray
0.38 kg - Engine air inlet duct
0.69 kg - Engine air inlet tube
0.24 kg - Power steering pump reservoir
0.78 kg - Radiator bracket
0.58 kg - Radiator cooling fan
0.78 kg - Radiator tank (2)
1.50 kg - Radiator cooling fan frame
0.52 kg - Air cleaner housing, upper (2)
0.64 kg - Air cleaner housing, lower (2)
Srcs for lightweight body panels & highgrade or lightweight hardware
Corvette Race Bodies (ACP)
Yoyodyne Ti
BarnHill Bolt Co.
RaceBolts.com
Titanium Joe/
