Kod på motorn samt intake
Postat: tor feb 15, 2007 10:29
av susanna113
Baktill på motorn står det J7 62 alt. 02 vad betyder dessa ?
På intake manifold står det 3744463 kan ej finna denna någonstans?
Någon anna som kan?
Postat: tor feb 15, 2007 10:33
av susanna113
Hmmmmmm denna intake går ju till en sb inte fn kan man sätta den på en BB ......LURAD????????
Postat: tor feb 15, 2007 13:06
Verkar ju vara ett Edelbrock Torker insug. Kanske samma nummer på BB som SB?
Re: Kod på motorn samt intake
Postat: tor feb 15, 2007 17:44
av KrilleN
[quote="susanna113"]Baktill på motorn står det J7 62 alt. 02 vad betyder dessa ?
quote]
BLOCK CASTING DATE
The block casting date indicates when the block itself was cast in the foundry. This date does not indicate when the motor was assembled and then later placed into the vehicle at the factory. The block casting date is usually found on the rear ledge of the block on the passenger side, but some later model blocks have the casting date on the driver's side of the rear ledge. Some of the early big blocks made in the Sixties have the block casting date located on the passenger side of the block near the freeze plug holes. On these, if the early big block is in the car you will have to get under the motor to see the casting date. Do it while the car is on a lift. The casting dates look something like this "E 12 7". The "E" stands for the month of the year with "A" being the month of January, "B" being the month of February and so on thru the letters to December. In this case the "E" stands for the month of May, the fifth month of the year and the fifth letter of the alphabet. The "12" stands for the 12th day of the month. The "7" is the year of the decade. Now unfortunately this could be '57, '67, '77, '87 or '97 depending on which part you are looking at. Some casting dates have both the year of the decade and the decade itself. They look like this "E 12 77", meaning May 12, 1977. The fun starts when you have a casting date from the first nine days of the month that look like this "D 2 6". Does that stand for April 2,1966 or does it stand for April 26th and the year is missing or hard to see? You have to look closely and carefully to be sure.
Postat: fre feb 16, 2007 3:04
av Korven
Enig med Peter i at du har en uorginal Torker innsug fordi Edelbrock har patent nr 3744463 på det. Disse innsugene leveres til forskjellige motorer. Her kan du lese
http://www.google.no/search?sourceid=na ... e+manifold
Orginal data på din bil finner du her
http://www.corvetteactioncenter.com/spe ... /71id.html
Legg ut en bild på din motor så kan vi gi deg bedre info.
Postat: fre feb 16, 2007 8:16
Va och hälsade på i garaget och insuget är ett Edelbrock Streetmaster. Lustigt att det verkar vara samma nummer på det insuget som på ett SB Torker.
Dock så e förgasaren lite "skum" då den verkar sakna Listnummer.
Edit: Efter lite lätt efterforskning så verkar Streetmaster vara en vidareutveckling av Torker insuget.
Postat: fre feb 16, 2007 16:23
av susanna113
Tack för titten, efterforskningarna fortsätter idag. Försökte komma in o kolla klumpen, utväxlingen....satiken vad trångt det är
o smutsigt
Postat: fre feb 16, 2007 16:35
av susanna113
Förra ägaren sa att det är en holley 780cfm ska kolla om jag hittar listnumret någonstans på den.
Postat: fre feb 16, 2007 23:49
av susanna113
Hittade listnumret Peter, 6212 var det alltså en 800 cfm.
Postat: fre feb 16, 2007 23:51
av susanna113
Hmm denna är inte så vanlig eller? spread-bore double-pumper
Postat: lör feb 17, 2007 18:34
av Stingray
susanna113 skrev:Hmm denna är inte så vanlig eller? spread-bore double-pumper
Den är inte så ovanlig, däremot lite väl stor kanske
