mohlin skrev:Men VAD skiljer dem?
Ex:
2001 Chevrolet Corvette Base Coupe Performance
-5,665 cc 5.7 liters 8 V front engine with 99 mm bore, 92 mm stroke, 10.1 compression ratio, overhead valve and two valves per cylinder
-Premium unleaded fuel
-Fuel economy EPA highway (l/100km): 9
-Multi-point injection fuel system
-Main 70 liter premium unleaded fuel tank
-Power: SAE and 261 kW , 350 HP @ 5,600 rpm; 360 ft lb , 488 Nm @ 4,400 rpm
2001 Chevrolet Corvette Base Coupe Handling
-ABS
-Four disc brakes including four ventilated discs
-Electronic traction control via ABS & engine management
-Immobilizer
-Limited slip differential
-Stability control
-Wishbone front and rear suspension with stabilizer bar independent with leaf springs
Ex:2001 Chevrolet Corvette Z06 Coupe Performance
-Fuel economy EPA highway (l/100km): 8.4
-Power: SAE and 287 kW , 385 HP @ 6,000 rpm; 385 ft lb , 522 Nm @ 4,800 rpm
2001 Chevrolet Corvette Z06 Coupe Handling
-ABS
-Immobilizer
-Responsive suspension
-Stability control
m.m....
