Halvljusautomatik
Halvljusautomatik
Min bil är utrustad med en skymningsfunktion som automatiskt tänder halvljuset när det börjar mörkna. Finns det något enkelt sätt att blockera detta.
Jajemen, det gör du under options i DIC:en.
Twilight Sentinel Automatic Lamp Control (Optional in United States, Standard in Canada)
Twilight Sentinel can turn your lamps on and off for you. A light sensor on top of the instrument panel makes the Twilight Sentinel work, so be sure it isn’t covered. You can customize your vehicle to turn Twilight Sentinel on or off (except for vehicles first sold in Canada). See “Driver Information Center (DIC)” in the Index to turn this feature on or off.
When Twilight Sentinel is turned on, you will see the following happen:
When it’s dark enough outside, the front turn signal lamps (DRL) will go off, and the headlamps and parking lamps will come on. The other lamps that come on with headlamps will also come on.
When it’s bright enough outside, the headlamps will go off, and the front turn signal lamps (DRL) will come on, as long as the exterior lamp switch is in the OFF position.
With Twilight Sentinel turned on, you can idle the vehicle with the lamps off, even when it’s dark outside. First set the parking brake while the ignition is in OFF. Then start the vehicle. The lamps will stay off until you release the parking brake.
Twilight Sentinel also provides exterior illumination as you leave the vehicle. If Twilight Sentinel has turned on the lamps when you turn off the ignition, your lamps will remain on until:
The exterior lamp switch is moved from OFF to the parking lamp position, or a delay time that you select has elapsed.
See “Driver Information Center (DIC)” in the Index to select the delay time that you want. You can also select no delay time.
If you turn off the ignition with the exterior lamp switch in the parking lamp or headlamp position, the Twilight Sentinel delay will not occur. The lamps will turn off as soon as the switch is turned off.
As with any vehicle, you should turn on the regular headlamp system when you need it.
The following are the options listed under the OPTIONS button:
Twilight (Optional in United States, Standard in Canada)
Press the OPTIONS button until TWILIGHT - OFF appears on the display, then use the RESET button to page through the following selections:
TWILIGHT - ON
TWILIGHT - OFF
If you choose TWILIGHT - ON, press the OPTIONS button again to display DELAY TIME 1 2 in the DIC.
Use the OPTIONS button to switch between delay time 1 and 2. You can increase the delay time by pressing button 1 (1 FUEL) or decrease the time by pressing button 2 (2 GAGES). Each bar is equal to 12 seconds.
TWILIGHT - ON
TWILIGHT - OFF
